CIChien
Mar 09, 2017Aspirant
Power LED of Orbi Satellite is blinking green
Dear friends, I got an issue: The Power LED of My Orbi Satellite is blinking green. What does this mean? In this situation I have also noticed that, the WiFi signal is weak. (I suppose ...
- Mar 11, 2017
The cause had been found.
I plugged the adapter into an old power line.
The voltage was unstable. That's why it was blinking green.Changing to an other power line solved the issue.
Thanks.
CIChien
Mar 10, 2017Aspirant
Thank you for your suggestion.
I will contact the support.
CIChien
Mar 11, 2017Aspirant
Thanks.
