legaleye3000
Jan 18, 2021Tutor
Power Outage = Only Some Devices Get IP Addresses
If the power goes out or I unplug the router for a few minutes, upon turning back on, only some devices are able to connect. Those that are able to connect will sometime disconnect and re-connect. I ...
Jan 22, 2021Guru - Experienced User
Try turning OFF the RBW and RBS then power cycle the RBR and see if the problem continues.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
Armor, Circle, and Set 20/40Mhz Coexistence to 20/40Mhz. Set Short preamble instead of Long preamble modes. Set 2.4G back to 100%. Save settings and reboot the router and satellite(s).
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
legaleye3000 wrote:If the power goes out or I unplug the router for a few minutes, upon turning back on, only some devices are able to connect. Those that are able to connect will sometime disconnect and re-connect. I find that after a day there are a couple of other devices that eventually reconnect, but largely many devices are always "attempting" to connect.
I have a RBR40 with a RBS20 and a RBW30. I'm on 2.6.1.36 for the RBR40 and latest firmware on the satellites. Here are my settings:
-Router mode
-Enable 20/40 = unchecked
-2.4 ghz transmit power = 50% (I just changed this to try it = no difference)
-Daisy-chain = off (the router and satellite placement doesn't make sense for daisy-chain)
-Implicit beamforming = on
-Mu-mimo = on
-Fast roaming = on
***Some things that have worked in the past to fix this: -change the ip allocation (192.168.1.1 to 192.168.5.1, as an example); changing wifi password; complete reset of router and satellites (sometimes this doesn't even work if I put the settings back); RTS/CTS changed to 2304 from default/max settings;
Any help appreciated. Thank you.
- legaleye3000Jan 22, 2021Tutor
The modem is a Arris BGW210-700. I have turned all devices off and on and synced and re-synced in every order I can think of without any change. The Arris is in bridge mode with wifi turned off so the Orbi is the only true router.
House is 4,000.00 sq ft, one floor. I'm not sure about the distance between the satellites and router; however, they have worked perfectly fine before where they are. When the power goes out, this situation occurs.
I've tried setting manual channels, which doesn't make a difference. We are spaced out between neighbors (1.5-2 acres between homes) so there are hardly any other wifi networks that I see.
Armor and Circle are always disabled. 20/40mhz is always unchecked and the preamble has always been checked to auto. Just confirming, you're saying to put a checkmark to enable 20/40mhz coexistence? And also, I should change the preamble from "auto" to "long"? Thanks.
- FURRYe38Jan 22, 2021Guru - Experienced User
legaleye3000 wrote:The modem is a Arris BGW210-700. I have turned all devices off and on and synced and re-synced in every order I can think of without any change. The Arris is in bridge mode with wifi turned off so the Orbi is the only true router.
Armor and Circle are always disabled. 20/40mhz is always unchecked and the preamble has always been checked to auto. Just confirming, you're saying to put a checkmark to enable 20/40mhz coexistence? Yes. And also, I should change the preamble from "auto" to "long"? Try Short first, then Long.
YOu might also try putting the Modem back in to router mode then set the RBR to AP mode. The Arris modem you have doean't actually have a full bridge mode: https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watchv=H7LOcJ8GdDo&app=desktop
- vajimJan 22, 2021Master
so it's safe to say the firmware is NOT the issue?
