SchaferEver
Jan 29, 2025Aspirant
Power supply for RBR50
Hello, Recently moved from a region where the power tension was 127 to a new region that is 220. All my orbi router and satellite have a power supply of 127. I am wondering if I can swap the po...
- Jan 29, 2025
Yes, any power supply that provides 12v/3.5amps will work as long as it has the same dimension/polarity plug and the electrical plug is compatible with the locality.
I would start with an Amazon search.
CrimpOn
Jan 29, 2025Guru - Experienced User
SchaferEver
Thanks Sir!
