Steven-Howells
Feb 04, 2020Aspirant
Power supply for RBS40V
I need to know the exact barrel size for the power adapter so I can buy a replacement, can any body help? Steve
CrimpOn
Feb 04, 2020Guru - Experienced User
This power supply on Amazon lists practically every Orbi model there is, and the barrel size appears to be the same for all of them.
(I am not recommending this product. Only noticing that there shure seem to be a lot of units with the same size barrel.)
- Steven-HowellsFeb 04, 2020AspirantUnfortunately the RBS40V (voice) has a different barrel size and also has a central pin, unlike all of the other models, I’m after the internal and external measurements for this barrel.
Thanks anyway- CrimpOnFeb 04, 2020Guru - Experienced User
Wow, "sharp eyes". Good catch!
How about this one:
https://www.amazon.com/Superer-Charger-Adapter-Netgear-RBS40V-200/dp/B08213QYSM
Here's one on eBay
