DiogoHC
Feb 05, 2020Guide
Power supply
I need a power supply for the Orbi RBS50Y that works in Portugal - 220v. The one that comes with the equipment is only rated for 100-120v
- Feb 06, 2020
It will work on 240 volts. Ignore the label.
Been there, done that. You just need an adpter for US - Portugal sockets.
What's the model number On the adapter? AD2110F10?
More than a year on, it still works.
CrimpOn
Feb 05, 2020Guru - Experienced User
This product claims to work with RBS50Y and comes with suitable adapter. (How they do that is somewhat of a mystery.)
Basically, you want an adapter that provides 2.5amp at 12v output, with the same size plug as most Netgear products take.
DiogoHC
Feb 05, 2020Guide
Thank you for your answer. The problem is that the RBS50Y is an outdoor equipment, and the original power supply has all kinds of protections against the elements - rain, dust, etc.
The one you mention should make it work, but without these protections - so it won’t work for me
