DiogoHC
Feb 05, 2020Guide
Power supply
I need a power supply for the Orbi RBS50Y that works in Portugal - 220v. The one that comes with the equipment is only rated for 100-120v
- Feb 06, 2020
It will work on 240 volts. Ignore the label.
Been there, done that. You just need an adpter for US - Portugal sockets.
What's the model number On the adapter? AD2110F10?
More than a year on, it still works.
DiogoHC
Feb 13, 2020Guide
michaelkenward wrote:
DiogoHC wrote:I need a power supply for the Orbi RBS50Y that works in Portugal - 220v. The one that comes with the equipment is only rated for 100-120v
Thanks for your help.
Actualy the model is AD10330LF, but I decided to give it a try on 220v and it works.
michaelkenward
Feb 13, 2020Guru - Experienced User
DiogoHC wrote:Actualy the model is AD10330LF, but I decided to give it a try on 220v and it works.
Great feedback. Very helpful. It could help someone who turns up here with the same issue.
It is puzzling that Netgear does not label adapters properly. Perhaps it is a legal thing in the USA.
- plemansFeb 13, 2020Guru - Experienced User
Maybe the certifications are different for other countries so its just cheaper to label them for single region use only?
- michaelkenwardFeb 13, 2020Guru - Experienced User
Sounds about right.
But that just tells me that Netgear is run by a bunch of cheapskates.
- plemansFeb 13, 2020Guru - Experienced UserAt least they didn't pull the capability from the power supply. That'd probably be even cheaper.
