DiogoHC
Feb 05, 2020Guide
Power supply
I need a power supply for the Orbi RBS50Y that works in Portugal - 220v. The one that comes with the equipment is only rated for 100-120v
- Feb 06, 2020
It will work on 240 volts. Ignore the label.
Been there, done that. You just need an adpter for US - Portugal sockets.
What's the model number On the adapter? AD2110F10?
More than a year on, it still works.
Feb 13, 2020Guru - Experienced User
At least they didn't pull the capability from the power supply. That'd probably be even cheaper.
michaelkenward
The Chinese factories that make these things probably charge more for single-voltage adapters.
