Southpaw32
May 13, 2020Guide
Powerline Ethernet for Backhaul?
I've got some powerline adapters that I'm not using, but could setup to use for backhaul on my RBK53 setup. This is my first experience with routers that use a backhaul, so I'm in the "learning" pha...
May 13, 2020Guru - Experienced User
PLs can be used.
Depends on the connection rate supported by the PL will dictate the bandwidth passing thru them and quality of there connections to each other. They have to be on the same power circuit.
PLs can cause noise on the power lines in the home.
I prefer ethernet vs PL
