dagiam
Feb 23, 2021Aspirant
Powerline Satellite Magenta
hi guys, i have a Netgear RBK40 + Netgear RBS40. everithing works fine until i try to add a powerline to the system. when i plug a powerline to the satellite with the lan cable it works for 1 mi...
dagiam
i had already seen this..
i need to understand why it is unable to obtain an IP address from your router or unable to your router after i plug the powerline..
vajim
Feb 23, 2021Master
magenta means your device is too FAR away
- dagiamFeb 23, 2021Aspirant
no, "Solid magenta. If your Orbi satellite ring is solid magenta, it is unable to obtain an IP address from your router or unable to your router."
this is why become magenta
- vajimFeb 23, 2021Master
dagiam wrote:no, "Solid magenta. If your Orbi satellite ring is solid magenta, it is unable to obtain an IP address from your router or unable to your router."
YES
why not just move it closer and prove me wrong that its something else?
i did it. but i doesn't depend from how far or close it is.
it happens only when i plug the powerline
