dagiam
Feb 23, 2021Aspirant
Powerline Satellite Magenta
hi guys, i have a Netgear RBK40 + Netgear RBS40. everithing works fine until i try to add a powerline to the system. when i plug a powerline to the satellite with the lan cable it works for 1 mi...
CrimpOn
Feb 24, 2021Guru - Experienced User
dagiam wrote:when i plug a powerline to the satellite with the lan cable it works for 1 minute (more or less), i have connection.
after this minute, the satellite gets the magenta solid state color. connection lost and i have to disconnect the powerline from the satellite.
I use Powerline to connect two Tivo units to my RBR50 router, specifically the TP-Link PA9020. Connected like this:
RBR50
to
8 port switch
to
Powerline
to
electric circuit----------------------------------------------------------------
to to
Tivo Tivo
Works fine. The Orbi has no idea there is a Powerline unit. All it sees is ethernet.
I have never connected Powerline to an Orbi satellite, but cannot imagine it would be any different.
Do you sync the Powerline units before connecting to the Orbi?
