mike_spooch
Feb 09, 2020Initiate
PPPoE with Centurylink 1G FTTH
the CL supplied router uses PPPoE and the status shows the WAN port is tagged. I do not see where I can tag the WAN port with the ORBI... is this possible?? thx, -mike s
Liquidcore
Feb 09, 2020Star
Advanced tab -> Advanced Setup -> VLAN / Bridge Settings
mike_spooch
Feb 10, 2020Initiate
thanks liquidcore. to add some additional info.. when I originally looked at the VLAN section in advanced, it appeared to only apply to the LAN ports, at least for the "by bridge group" section. however selecting "by VLAN tag group" it worked for the WAN port. also note Centurylink expects VLAN tag 201.
