Rockinjt
May 08, 2018Follower
Pre Purchase Question
Hi Folks,
I am new to the forum so treat me gently!
I am not a technical person and I am trying to get wifi from my house to my shop without having to dig a ditch from house to shop. My h...
- May 08, 2018
I second the last post! Get a two satellite system from Costco. Configure it with the latest firmware and dasiy chain it wirelessly to your shop. Test it for a week or two under your normal and difficult circumstances. Return it if it sucks!
BTW, I have a single satellite system in my 3000 sq ft house. The base router sits about 50 feet from the satllite and the satellite covers my shop which is an attached garage about 50 feet from the satellite through two concrete block & stucco wall!. The signal isn't great but it allows me to stream Pandora and surf the web from my shop. I currently get about 80-100 Mbps in my shop with a 400Mbps Xfinity ISP service plan. Additionally, I have a solar panel array that has a WiFi output. I can see that output and it is through a third concrete block/stucco wall! (Of course this is all on the 2.4gHz band.)
tsig
May 08, 2018Luminary
I would put the router in the house and hardwire a single satellite in the shop. If the single in the shop doesn't cover it, easy enough to add another. For sure though hardwire the satellite.
