BillYoung
Mar 09, 2019Luminary
Primary Network drops, but the Guest Network doesn't
Furrye38 or to whomever can answer this:
Ever since I upgraded my firmware from 2.2.1.210 to 2.2.1.212 to 2.3.0.32, my Primary Network has become unstable. It drops connections to the internet...
- Mar 11, 2019
Wow, something isn't right.
When you had the Orbi online and working before, what mode was the modem in? Bridged?
You can do this while the ORbi is OFF line from the modem. Download v212 and v32 file to a wired PC. Don't connect the RBR to the modem just yet.
Use a wired PC with the RBR. Re-Send the v212 file first using the RBRs web page manual FW update UI. I would use IE11 or FF browsers for this. After v212 is applied, turn around and send the v32 file to the RBR using same process. After it's applied, use the routers web page to ERASE (factory reset) the RBR. Keep the wired PC connected. Don't connect the RBR to the modem just yet.
With the web browser, log in to orbiligin.com and instead of walking thru the setup wizard, skip it. You'll still need to give a PW and recovery info. Do this.
When you get to the main page of the Orbi, navigate to wireless settings and setup a SSID name and PW, give a different SSID name from what your using on the modem. This will be just temporary. Save settings. Don't enable Guest Network.
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Look at a mobile device and check to see if this new SSID appears on the mobile device. If so, connect to this SSID. Check to see if you get a IP address on the device as well.Guest Network should not appear.
If you can get this far, you can configure the Orbi for AP mode and connect it up to the ISP Modem. Besure to DISABLE ALL wifi radios on the ISP modem. Leave the modem in router mode, not bridged. Run the Orbi for a while to see if the wifi SSID remains and that you don't see it drop off.
BillYoung wrote:
FURRYe38: Sorry to inform you this, but doing what you said has totally wrecked my Orbi network. Now it allows you to access the Router, but not the Internet. I tried to fix the problem several times, but it keeps giving me the same thing - it tells me that my modem was not rebooted during the process (which it has been now several times) or that the cables are plugged into the wrong place or not plugged in well enough (neither is the case; the cables are in the right place and are plugged in all the way). So I tried downgrading the firmware to 2.2.1.212. Successfully done, But no improvement in the situation. The network still tells me the same information. At that point, I have removed the Orbi from my system, and turned my modem into a modem/router combo. Now I can access the internet to tell you what has been happening. It will be a couple of days to get back to trying to fix the Orbi. So, should I: a. Downgrade the firmware to 2.2.1.210 b. Upgrade the firmware again to 2.3.0.24 and see what further instructions await. Please let me know what to try next. I am at a loss.
Mar 10, 2019Guru - Experienced User
I would do a factory reset on the system and setup from scratch. Others have reported having odd problems after upgrading. Reset seemed to fix.
Ever since I upgraded my firmware from 2.2.1.210 to 2.2.1.212 to 2.3.0.32, my Primary Network has become unstable. It drops connections to the internet regularly.
However, if I connect to my Guest Network, my connections to the internet do not drop.
I have not tried doing anything special to the router after upgrading. Should I have done something to the router like say rebooting, or resyncing?
Thanks in advance for your prompt response.
- BillYoungMar 10, 2019LuminaryFURRYe38: Sorry to inform you this, but doing what you said has totally wrecked my Orbi network. Now it allows you to access the Router, but not the Internet. I tried to fix the problem several times, but it keeps giving me the same thing - it tells me that my modem was not rebooted during the process (which it has been now several times) or that the cables are plugged into the wrong place or not plugged in well enough (neither is the case; the cables are in the right place and are plugged in all the way). So I tried downgrading the firmware to 2.2.1.212. Successfully done, But no improvement in the situation. The network still tells me the same information. At that point, I have removed the Orbi from my system, and turned my modem into a modem/router combo. Now I can access the internet to tell you what has been happening. It will be a couple of days to get back to trying to fix the Orbi. So, should I: a. Downgrade the firmware to 2.2.1.210 b. Upgrade the firmware again to 2.3.0.24 and see what further instructions await. Please let me know what to try next. I am at a loss.
- FURRYe38Mar 11, 2019Guru - Experienced User
BillYoung wrote:
FURRYe38: Sorry to inform you this, but doing what you said has totally wrecked my Orbi network. Now it allows you to access the Router, but not the Internet. I tried to fix the problem several times, but it keeps giving me the same thing - it tells me that my modem was not rebooted during the process (which it has been now several times) or that the cables are plugged into the wrong place or not plugged in well enough (neither is the case; the cables are in the right place and are plugged in all the way). So I tried downgrading the firmware to 2.2.1.212. Successfully done, But no improvement in the situation. The network still tells me the same information. At that point, I have removed the Orbi from my system, and turned my modem into a modem/router combo. Now I can access the internet to tell you what has been happening. It will be a couple of days to get back to trying to fix the Orbi. So, should I: a. Downgrade the firmware to 2.2.1.210 b. Upgrade the firmware again to 2.3.0.24 and see what further instructions await. Please let me know what to try next. I am at a loss.- BillYoungMar 11, 2019Luminary
FURRYe38:
In answer to your questions:
Smart/RG SR360n
Bridged. To get my wired PC working through the Orbi, I set it to Routing.
Many, like 6 or 8.
I will do what you suggest. The firewall is already at 2.2.1.212.
