Rickd83
Nov 22, 2022Aspirant
Printer OFFLINE on ORBI, but IDLE on home network.
If my computer is on the home network, the printer shows IDLE. If the computer is on the ORBI network, the printer indicates OFFLINE. If I set my computer to ORBI network and reinstall the printer, t...
Nov 22, 2022Guru - Experienced User
What Orbi model do you have?
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
- Rickd83Nov 22, 2022Aspirant
Orbi Model RBR50
Firmware: V2.7.4.24
Router: Netgear Nighthawk Model CAX30
Rick
