Rickd83
Nov 22, 2022Aspirant
Printer OFFLINE on ORBI, but IDLE on home network.
If my computer is on the home network, the printer shows IDLE. If the computer is on the ORBI network, the printer indicates OFFLINE. If I set my computer to ORBI network and reinstall the printer, t...
Nov 22, 2022Guru - Experienced User
I recommend bridging the CAX30 modem if your going to use the Orbi system as a wifi mesh system.
Would help the printer maintain connection to the one wifi system.
