madbrain
Sep 23, 2017Luminary
Printer wired by Ethernet to Orbi satellite has 24% packet loss . Satellite has 0% packet loss
The RBR50 is running in AP mode downstairs in the front of the house. I have an RBS50 satellite in one room way in the back of the house, also downstairs. I have a networked printer attached to ...
DarrenM
Sep 25, 2017Sr. NETGEAR Moderator
Hello Madbrain
Have you tried with another ethernet cord and use another port on the satellite?
DarrenM
madbrain
Sep 25, 2017Luminary
Darren,
I have not tried another Ethernet cable, but I was using the same Ethernet cable to connect the printer between either the powerline AV1200 and the RBS50 satellite. I think that pretty much rules out the cable. It's a fairly short cable BTW (6f)t. Just checked and it was a CAT5 hooked up to the rightmost port of the satellite.
I will try a different port on the satellite, and different cable also. I hooked it up to the 2nd port from the right on the satellite and just restarted the 2 ping tests.
The problem is not instant as far as reproducibility. It only really shows up in my 24 hour+ ping tests. So far this weekend all has been good.
- madbrainSep 27, 2017Luminary
So far, issue is not reproducible, I suppose that is good news in a way.
