75aces
Dec 04, 2019Initiate
Printing issues -RBR50
Newbie here. Found a solution to my problem and maybe it will work for others too. I recently purchased Orbi RBR50. The product works as advertised. Until, I realized that my printer was not com...
ekhalil
Dec 04, 2019Master
From your description I get it that your Orbi is set in AP Mode, correct?
- 75acesDec 04, 2019InitiateThe only 2 setting changes I made was I went to the highest security protocol and turned off the 5ghz setting. The reason I turned off the 5ghz setting was because of some devices I have can only communicate at 2.4ghz.
