sursan13
May 25, 2019Aspirant
Problem accessing NAS (DLNA) from the satelite
Hello, I have problems accessing my Synology NAS via DLNA from a device connected to the RBS. My configuration is: - VDSL router from my Internet provider - Orbi RBK50 system, with the RBR con...
May 26, 2019Guru - Experienced User
Is Daisy Chain enabled on the RBR? Try disabling it if it is and see. Under Advanced Tab/Advanced Settings/Wireless Settings
- sursan13May 26, 2019Aspirant
Hello,
Thank you for the suggestion, I will try.
But just for my understanding, suppose I will add a 2nd sattelite, this setting will not allow the sattelites to connect between them, only to the router, right?
And just a thought, this seems to be a problem inside the sattelite, "routing" the wireless connection to its wired ports, while the wireless part works fine. I don't know how this parameter works internally, but it is kind of strange to change a wireless parameter when the wireless part works fine and the problem is with the wired part ... Am I totally wrong? :)
As I said, I will try, but according to the description it will reboot the entire system, I will find the right moment ;)
Just one more thing I forgot to mention, both RBR and RBS have the latest firmware available, V2.3.1.60
Thank you again!
- FURRYe38May 26, 2019Guru - Experienced User
Ya seems like the routing in the RBS is messed up since when connecting to the RBR doesn't post this problem.
I would try a full factory reset on the RBS and RBR and setup from scratch and see if this helps any.
