sursan13
May 25, 2019Aspirant
Problem accessing NAS (DLNA) from the satelite
Hello, I have problems accessing my Synology NAS via DLNA from a device connected to the RBS. My configuration is: - VDSL router from my Internet provider - Orbi RBK50 system, with the RBR con...
CrimpOn
Jun 16, 2019Guru - Experienced User
sursan13 wrote:My configuration is:
- Orbi RBK50 system, with the RBR configured as AP and the RBS connected via WiFi
- The NAS connected to the RBR - wired
- My Samsung TV (2019) connected to the RBS - wired
Do these various devices have IP addresses "assigned" to them (in the web interface, Advanced Tab, LAN Setup)?
or, do they all get whatever the DHCP on the VDSL router gives them at the time?
- sursan13Jun 16, 2019Aspirant
Hello,
They all get whatever the DHCP on the VDSL router gives them at the time.
Thanks!
- CrimpOnJun 16, 2019Guru - Experienced User
Another silly question: When the TV is moved from one Orbi device to the other, does the Orbi get reset? (i.e. do a Reboot, or temporarily pull the power and let it power on again)?
I am probably just waaay wrong, but I wonder if the switch in the Orbi "remembers" where a MAC address is when it shouldn't. Ethernet switches have tables in them that say, "packets for these specific MAC addresses can be found out this specific ethernet port."
- mikew_ntJun 16, 2019AspirantI don't move my device between reboots and the problem is consistent.
- mikew_ntJun 16, 2019AspirantMine are all DHCP
