bfrank
Mar 30, 2019Aspirant
Problem adding second RBS50 to my RBR50
At least a year ago I bought an RBR50 that came with two RBS50's. I've only been using one of the RBS50's and now want to add the second one. It appears to have synced, but I am having trouble upda...
- Mar 30, 2019
You need to first get the RBS #2 updated to a intermediate version since it's on a very old version of FW. Load v2.0.0.74 first. Then try to load v210
bfrank wrote:
At least a year ago I bought an RBR50 that came with two RBS50's. I've only been using one of the RBS50's and now want to add the second one. It appears to have synced, but I am having trouble updating the software on the second one. I downloaded the software, but am unable to upload it manually to the second RBS 50.
RBR 50 is V2.2.1.210
RBS 50 (#1) is V2.2.1.210
RBS 50 (#2) is V1.4.0.18
Please let me know if you have any suggestions. Thank you.
Chuck_M
Mar 30, 2019Mentor
What is precluding you from uploading? You cannot connect? It fails?
Try using your web browser (preferably Chrome) to go directly to the Satellite's IP and GUI.
To do this go to your ROUTER's web gui, click ATTACHED DEVICES and note the IP address of the satellite you want to upgrade.
Then put that IP address in your web browser and use the same login credentials (admin & PW)
You should be able to do a firmware upgrade directly from the satellite GUI by clicking FIRMWARE UPDATE and uploading the .IMG file you have unzipped on your PC.
If this fails, please let us know the indication of failure.
If you have questions, ask before you attempt.
BTW, your entire system needs firmware updates to .44 after you do this satellite. (Update satellites first)
bfrank
I sign into orbilogin.com. Advanced>Administration>Firmware Update>Manual Update.
Select specific RBS50 and click Update.
Click Browse. Click RBS50-V2.2.1.212img. Click Choose.
Please select correct configuration file (see attached screenshot) pops up. Can't get past this.
Am I downloading the wrong update?
Thank you.
