dano17
Feb 23, 2020Tutor
Problem after Orbi RBR50 firmware update to 2.5.1.8
I recently update the firmware to 2.5.1.8 and have had nothing but problems getting all devices working properly again. The reason that I updated was that devices were disappearing from the Orbi app...
- Feb 28, 2020
Thanks again to all who responded to my posts. I was able to isolate the issue to the Pentair protocol adapter not releasing it's old IP address by reverting back to my older Netgear WNDR3700, where it displayed the same bad IP address. A tech support call to Pentair provided some critical undocumented steps to reset the protocol adapter (the reset button on the adapter must be pushed 3 times within 2 seconds). The adapter then released the old IP address and accepted a new one assigned by the router. I also regressed back to the RBR50 / RBS50 V2.3.5.30 firmware to address the buggy 2.5.1.8 firmware whereby the devices (including the satellite) disappear over time rather than showing as attached devices. I'm back up and running now. I'm disappointed in the Orbi firmware, as there has been something wrong with each version that prevented it from operating as advertised. The stuck IP address, however, was a Pentair documentation issue, compounded by the Orbi firmware update. Thanks again for the assistance, and hope my post can help someone else in the future.
CrimpOn
Feb 24, 2020Guru - Experienced User
dano17 wrote:During the original Orbi installation, the subnet mask IP range was 172.16.0.x. Not sure why it chose this range, but I went with the default. During the recent firmware update to 2.5.1.8, the subnet mask IP range was changed to the typical 192.168.1.x. As far as I can tell, all of the devices except for the Pentair adapter updated, while the Pentair adapter kept an IP address of 172.16.0.9. Now I cannot communicate with the Pentair system, and I've tried resettting the adapter, powering down the adapter and the Pentair controller in every conceivable order.
The solution is to set up the Pentair controller from scratch so that it gets a correct IP address. I'm happy to look at the Pentair setup instructions if you supply the exact model number and the user manual is on the web.
One thing you might try is to go into the Orbi web interface, Advanced Tab, LAN Setup, and assign a specific IP address to the Pentair using the MAC address shown on the Attached Devices display. Then, power off the Pantair and power it back on. If it is asking the Orbi for an IP address using DHCP, it might get the new one. If the Pentair has been set up with a "static IP", then the only way to get it changed is through a fresh setup.
