dano17
Feb 23, 2020Tutor
Problem after Orbi RBR50 firmware update to 2.5.1.8
I recently update the firmware to 2.5.1.8 and have had nothing but problems getting all devices working properly again. The reason that I updated was that devices were disappearing from the Orbi app...
- Feb 28, 2020
Thanks again to all who responded to my posts. I was able to isolate the issue to the Pentair protocol adapter not releasing it's old IP address by reverting back to my older Netgear WNDR3700, where it displayed the same bad IP address. A tech support call to Pentair provided some critical undocumented steps to reset the protocol adapter (the reset button on the adapter must be pushed 3 times within 2 seconds). The adapter then released the old IP address and accepted a new one assigned by the router. I also regressed back to the RBR50 / RBS50 V2.3.5.30 firmware to address the buggy 2.5.1.8 firmware whereby the devices (including the satellite) disappear over time rather than showing as attached devices. I'm back up and running now. I'm disappointed in the Orbi firmware, as there has been something wrong with each version that prevented it from operating as advertised. The stuck IP address, however, was a Pentair documentation issue, compounded by the Orbi firmware update. Thanks again for the assistance, and hope my post can help someone else in the future.
dano17
Feb 24, 2020Tutor
Thanks for your post. The modem is not a router also. It is a Netgear CM1100.
