dano17
Feb 23, 2020Tutor
Problem after Orbi RBR50 firmware update to 2.5.1.8
I recently update the firmware to 2.5.1.8 and have had nothing but problems getting all devices working properly again. The reason that I updated was that devices were disappearing from the Orbi app...
- Feb 28, 2020
Thanks again to all who responded to my posts. I was able to isolate the issue to the Pentair protocol adapter not releasing it's old IP address by reverting back to my older Netgear WNDR3700, where it displayed the same bad IP address. A tech support call to Pentair provided some critical undocumented steps to reset the protocol adapter (the reset button on the adapter must be pushed 3 times within 2 seconds). The adapter then released the old IP address and accepted a new one assigned by the router. I also regressed back to the RBR50 / RBS50 V2.3.5.30 firmware to address the buggy 2.5.1.8 firmware whereby the devices (including the satellite) disappear over time rather than showing as attached devices. I'm back up and running now. I'm disappointed in the Orbi firmware, as there has been something wrong with each version that prevented it from operating as advertised. The stuck IP address, however, was a Pentair documentation issue, compounded by the Orbi firmware update. Thanks again for the assistance, and hope my post can help someone else in the future.
dano17
Feb 24, 2020Tutor
Thank you for the quick post advice. Unfortunately, I see no way to change the IP address per your advice "go into the Orbi web interface, Advanced Tab, LAN Setup, and assign a specific IP address to the Pentair using the MAC address shown on the Attached Devices display". I have tried to block the device, as well as reserve it's IP address to a 192.168.1.XXX address, but the old 172.16.0.9 IP address remains no matter what I do. This seems like a bug to me. Your advice seems routine for other routers (my previous router was a an older Netgear, which I used this feature on occasion). So, even when I try to reserve a proper address, the router ignores my input and maintains the old invalid IP address for this one device.
I have already performed a factory reset on the Orbi, and the old IP address, for some reason, is stuck on the Pentair adapter MAC. Never seen this happen before, and running out of ideas. Out of curiosity, does the satellite possibly maintain a copy of the old IP address? When I performed a factory reset of the router, the satellite was probably still powered up. Like I said, I'm running out of ideas. Thanks...
eljarviso
Feb 25, 2020Luminary
You should be able to change the settings on the web interface in advanced -> setup -> LAN setup. You should be able to change the routers LAN IP which should change the subnet dhcp uses. Unfortunately I’m running my setup in AP mode so this section is greyed out and I can’t get into it to see exactly what settings need to be changed.
