ohaya100
Jul 30, 2023Aspirant
Problem getting VPN enabled and tested
Hi, The network configuration we have in our home is: - Verizon Fios Modem/router - Orbi mesh is connected to one of the LAN-side ports of the Fios modem - The LAN side network of the Fios is ...
Jul 30, 2023Guru - Experienced User
What Orbi model do you have?
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
Try option #2 first...
