ohaya100
Jul 30, 2023Aspirant
Problem getting VPN enabled and tested
Hi, The network configuration we have in our home is: - Verizon Fios Modem/router - Orbi mesh is connected to one of the LAN-side ports of the Fios modem - The LAN side network of the Fios is ...
michaelkenward
Jul 31, 2023Guru - Experienced User
As others have said, this is a classic case of double NAT.
I chip in only to say that the key missing detail is the modem number of this Verizon Fios Modem/router.
It is usually easier to put this into bridge (modem only) mode than to go into PhD grade network engineering. Then just leave it to the Orbi router to manage the network.
The model number would tell us if this is one of those modem/routers that allows bridge mode. Tis such a common topic that a Google/Bing search will usually have pointers.
