ohaya100
Jul 30, 2023Aspirant
Problem getting VPN enabled and tested
Hi, The network configuration we have in our home is: - Verizon Fios Modem/router - Orbi mesh is connected to one of the LAN-side ports of the Fios modem - The LAN side network of the Fios is ...
ohaya100
Jul 31, 2023Aspirant
Hi,
Thanks for all the responses.
FYI, the FIOS modem/router is "cr1000a".
I found a user guide for it here: https://scache.vzw.com/dam/support/pdf/user_guide/cr1000a-verizon-router-user-guide.pdf
That guide has a list of features including:
VPN (VPN pass through only)
But that guide above doesn't have any other info on that feature :(...
Jim
Jul 31, 2023Guru - Experienced User
Something to contact the ISP about for there help and support information regarding there equipment.
