DeeKell
Oct 23, 2018Follower
Problem logging into to Orbi on every device
Hi all,
hoping someone could help please.
I purchased an RBK50 +1 satellite about a month ago, to replace a Nighthawk x6 router that seemed to be faulty. Setup went fairly smoothly, though th...
Oct 24, 2018Guru - Experienced User
What FW is currently loaded?
If you updated to recent FW v.210, try enabling Daisy Chain. Some have mentioned that this seems to be working in reverse order, enabling means disabled actually.
https://community.netgear.com/t5/Orbi/Firmware-2-2-1-210-and-connection-problems-Skybell/m-p/1649275/highlight/true#M43001
Does a wired PC and browser connect to the Orbi routers web page. You might walk thru the setup wizard there and complete the setup process fully with a PC an browser first.
