Codeblue229
Aug 27, 2018Aspirant
Problem of newly added Orbi ethernet backhaul
I am using a RBR50 as my main router connecting to two satellites wirelessly in daisy chain like this:
RBR50 <==> RBS50 <==> RBW30
In order to extend my wifi signal, I bought a new RBS50 and ...
Flukey
Mar 19, 2019Initiate
When I first setup my Orbi network, wifi backhaul worked fine and I was getting 90 Mbps internet speed from my connected devices. When I changed to a ethernet backhaul all my network had issues, and my internet speed dropped to 20-30 Mbps. I kept changing from wifi to ethernet backhaul and back and the issue was consistent. I thought I had the latest firmware version (2.2.1.210) because the online update feature in the orbi admin panel said I had the latest firmware.
It was only when I looked into this further and found there is a more recent firmware (2.3.0.32) that can only be installed by a manual update. Even more confusing was that you first have to manual update to firmware 2.2.1.212 before you can then manually update to 2.3.0.32. (see netgear download page)
Anyway, once I updated to the latest firmware the ethernet backhaul works fine, with no network issues and no loss of intenet speed.
- Chuck_MMar 19, 2019Mentor
The reason you had to update to an intermediate firmware is because the original firmware limited the size of an uploaded firmware image. When .28 and .32 came out, they were larger than that original size, so they had to modify the limit and the only way you could do that was through (yet another) firmware update.
Glad to hear your issue appears to be resolved. They did a lot of work on the backhaul system in the .32 version.
- FURRYe38Mar 20, 2019Guru - Experienced User
Glad it's working. Yes the intermediate v212 is needed for the RBR only. You can directly update the RBS to v32.
Enjoy.
