Codeblue229
Aug 27, 2018Aspirant
Problem of newly added Orbi ethernet backhaul
I am using a RBR50 as my main router connecting to two satellites wirelessly in daisy chain like this:
RBR50 <==> RBS50 <==> RBW30
In order to extend my wifi signal, I bought a new RBS50 and ...
Flukey
Mar 19, 2019Initiate
When I first setup my Orbi network, wifi backhaul worked fine and I was getting 90 Mbps internet speed from my connected devices. When I changed to a ethernet backhaul all my network had issues, and my internet speed dropped to 20-30 Mbps. I kept changing from wifi to ethernet backhaul and back and the issue was consistent. I thought I had the latest firmware version (2.2.1.210) because the online update feature in the orbi admin panel said I had the latest firmware.
It was only when I looked into this further and found there is a more recent firmware (2.3.0.32) that can only be installed by a manual update. Even more confusing was that you first have to manual update to firmware 2.2.1.212 before you can then manually update to 2.3.0.32. (see netgear download page)
Anyway, once I updated to the latest firmware the ethernet backhaul works fine, with no network issues and no loss of intenet speed.
Mar 20, 2019Guru - Experienced User
Glad it's working. Yes the intermediate v212 is needed for the RBR only. You can directly update the RBS to v32.
Enjoy.
