CandaceVan
Dec 15, 2017Aspirant
Problem updating firmware on add-on Orbi satellite
I have an add-on satellite (RBS 50) that has never given me trouble until I went to manually update the firmware on my router and two satellites. All went well with the router and orginal satellite, ...
Havok_
Dec 21, 2017Star
I had this problem as well. What worked for me was a simple reboot of the main router and then going through the connection process of Router to Satellite. Once I did that, when I went back to the firware update screen it located the new version. This was for my move to 2.1.1.16 from 2.0.0.74.
Also, possible to factory reset the satellite so it is as new to again add to the network?
NickC4555
Dec 21, 2017Star
I had the same problem with one satellite refusing to authenticate (the other one was fine), but it worked after I updated the router.
