MarkD1944
Mar 14, 2020Aspirant
Problem Updating FIrmware RBR20
I got an email today from Netgear that indicates that there is a firmware update for my router to V2.3.5.36. I currently have V2.3.5.26. When i go to update the router says there is no update. ...
- Mar 22, 2020
Just for grins I tried it againj today. The update worked fine -- I'm updated to version .30
I suspect that there was something wrong with the versioning at Netgear, but really I do not care as it seems to be resolved.
MarkD1944
That is not the problem. I was able to download the update, but when I tried to implement the 'Manual Update' the software would not allow me to get past the next username/password. It was the correct name/password, same as that that I logged in with.
Mar 14, 2020Guru - Experienced User
Reboot the RBR. Clear all browser caches. Exit then relaunch the browser. Try a different browser. After the RBR has rebooted, log in and go into immeditally to try to update the FW using the web browser on your wired PC.
