Nyflgirl's avatar
Nyflgirl
Problem with adding satellite
I have my Ac3000 set up and working. I wanted at add a 2nd satellite so I got a rbs40. I have it all hooked up and it’s showing both satellites online, however if the rbs40 is plugged in and you are n...
  • FURRYe38's avatar
    Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password.
    Can you get logged in and see the FW version here?
