Nyflgirl
Dec 10, 2020Aspirant
Problem with adding satellite
I have my Ac3000 set up and working. I wanted at add a 2nd satellite so I got a rbs40. I have it all hooked up and it’s showing both satellites online, however if the rbs40 is plugged in and you are n...
- Dec 11, 2020
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password.
Can you get logged in and see the FW version here?
Nyflgirl
Dec 11, 2020Aspirant
I can’t see if it would be connected via Orbi web interface (http://orbilogin.net), When I plug it in, and try to interface, nothing happens. It won’t connect to the orbi router. It seems like the satellite blocks the wifi connection for anyone near it.
Dec 11, 2020Guru - Experienced User
What FW version is loaded on the 50 series system? Possible the FW is newer than whats on the 40 series RBS which probably needs to be updated...
- NyflgirlDec 11, 2020AspirantI was able to log into the interface, went to software update and the update for the rbs40 failed. Everything else is already updated.
- FURRYe38Dec 11, 2020Guru - Experienced User
- NyflgirlDec 11, 2020AspirantI log in with admin and password on the bottom of the satellite and I get 401 unauthorized, access denied..has no supplied correct. I tried multiple times, same error
- NyflgirlDec 11, 2020AspirantSo the automatic update failed, I tried the manual update as the satellite has version V1.11.0.20
On net gear website and download the firmware update, when I click upload I get a error message that says “the firmware file is incorrect” I tried the latest firmware, the same version it has and one up from what it has, they all say the file is incorrect.
My rbs50 is on V2.5.2.4 - NyflgirlDec 11, 2020AspirantI just realized the new satellite I got says orbi mini rbs40? I can’t find a firmware update for it anywhere.
