Nyflgirl
Dec 10, 2020Aspirant
Problem with adding satellite
I have my Ac3000 set up and working. I wanted at add a 2nd satellite so I got a rbs40. I have it all hooked up and it’s showing both satellites online, however if the rbs40 is plugged in and you are n...
- Dec 11, 2020
Wire connect 1 PC to the back of the RBS. Factory reset the RBS, wait about 5 minutes. The PC will get a IP address from the satellite. The RBS will be 192.168.1.250. Use this IP address in a web browser to log in to the satellites web page. Log in as admin and password.
Can you get logged in and see the FW version here?
Nyflgirl
Dec 11, 2020Aspirant
I was able to log into the interface, went to software update and the update for the rbs40 failed. Everything else is already updated.
Dec 11, 2020Guru - Experienced User
- NyflgirlDec 11, 2020AspirantI log in with admin and password on the bottom of the satellite and I get 401 unauthorized, access denied..has no supplied correct. I tried multiple times, same error
