Zaichik
May 08, 2021Aspirant
Problem with Amazon Echo
I have number of Amazon Echo devices, which all connect to my Netgear Orbi mesh network. All was working well until a few days ago. Now, one of my Echo Shows won't connect. Initially, both the Show...
- May 08, 2021
Zaichik wrote:
For some reason, no matter how many times I request for the device to be allowed like all the others, the router refuses to unblock it.
Does anyone know why? I've had to turn off access control for now because that's the only way I can restore access to the Echo Show.Access Control seems really touchy (to me). The tables can be edited only when Access Control is ON. It might be possible to turn the device off, and then erase it from the "Blocked devices which are not connected" table.
I am totally comfortable with not enabling Access Control. Internet calculators claim it will take hackers about 4 billion years to brute force my WiFi password and I would surely notice a car parked outside with a hacker trying to break into my residential WiFi network. (and...What For? It's not like I am a bank or business with secrets or money to protect.)
If you are willing to leave Access Control not enabled, there is no reason to Factory Reset the Orbi.
Zaichik
I've found out the problem is but I still can't completely fix it.
I've been into the advanced settings on the Orbi Web interface and found that the Echo Show has somehow been set to blocked under the access controls. I have no idea how that could have happened because it's months since I've logged in there.
CrimpOn
May 08, 2021Guru - Experienced User
- ZaichikMay 08, 2021AspirantDeleting the device from the blocked but not online list turned out to be the solution. For some reason the Echo Show appeared in that list about 20 times. Deleting all the entries restored its access without having to turn off access control.
Goodness knows how all that happened but thanks so much for helping me fix it đ
