renoryan007's avatar
renoryan007
Follower
Jan 13, 2023
Problem with Firmware Update on Orbi CBR-750 version 4.6.14.4
After updating my firmware on my Orbi some of my devices are now showing N/A,  Any help would be appreciated.
  • FURRYe38's avatar
    How did you apply the FW update? Auto update or manually?
    What browser are you using? Happens in other browsers?
    Has a power off for 1 minute then back ON with the ISP modem and router been performed since last update?
    Turn off and unplug modem.
    Turn on computers and rest of network.
    Has a factory reset and setup from scratch been performed since last FW update? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
  • FURRYe38's avatar
    Any progress on this?
    • KKCC799's avatar
      KKCC799
      Guide
      Were you able to resolve this issue? I’m having the same problem.
      • FURRYe38's avatar
        Please make a new post and we'll help you out.
        Thank you.
        The OP hasn't been on since they first posted. đꙄ
