midlevelknowhow
Mar 05, 2023Follower
Problem with Orbi RBR40 router and Cat 6 connection to satellite
Wifi to satellite working with RBR40 router. Cat 6 Ethernet connection to satellite not working. Also, disrupts system.
Mar 05, 2023Guru - Experienced User
Move the satellite right next to the router and use a good quality 6ft cable to connect them to each other and test them that router.
I've had a ton of times where a bad cable caused issues with the backhaul
