sherman2423's avatar
sherman2423
Follower
Jul 13, 2020
Problem with RBR50 and ROKU
I had a weird thing happen this weekend. I have a 2018 Roku 4k premier in my theater room and a 2019 premier in my living room. I tried to watch Greyhound on the 2018 roku, it would not load the video it told me to check connection. cI updated both ROKU's. I tried another movie fromm Apple TV plus app and it worked, tried another and it didn't only certain movies would play from the app. I tried for hours and could not get it to load. Went to the living room and it played? I have an Orbi RBR50 router and the satellite is upstairs in the theater room hard wired to the ROKU. What could possibly be wrong? Could this be a problem with the ORBI?
1 Reply
  • FURRYe38's avatar
    Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
    https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
