jt76
Dec 06, 2020Guide
Problem with RBS50 - does not connect to RBR50
I bought a used RBR50 + RBS50 combo a few months back. I was able to install RBR50 and with some trial and error the RBS50. However, the RBS50 kept on disconnecting from the RBR50. So I updated the f...
jt76
Dec 06, 2020Guide
Update: A new developement on the RBS50. When I moved it to another location and powered it up I saw the top ring LED flash white five times and then it is only flashing Green. The power LED shows up as Green.
Will not Sync up with the RBR50.
- vajimDec 06, 2020Master
Don't trust the app
Refresh it or reinstall it
many never use it
login into your router via a web browser
- jt76Dec 06, 2020Guide
vajim wrote:Don't trust the app
many never use it
I have tried Adding Satellite through the web browser as well. No luck.
I now have the RBS50 ring LED flashing White now! I have no idea why the ring LED flashing Green before. The instructions in the web App say that the ring LED should be solid White. Not sure how to get it to that state.
- John_BaDec 07, 2020LuminaryI tried setting up a new system via pc wired and I wasn't able to get a link eather. Thy just came up with a msg re the app. I tried all the address I could find and in the end had to use the app. Some 50s may well have been setup to block wired setup, I am in the UK.
