jt76
Dec 06, 2020Guide
Problem with RBS50 - does not connect to RBR50
I bought a used RBR50 + RBS50 combo a few months back. I was able to install RBR50 and with some trial and error the RBS50. However, the RBS50 kept on disconnecting from the RBR50. So I updated the f...
vajim
Dec 06, 2020Master
Don't trust the app
Refresh it or reinstall it
many never use it
login into your router via a web browser
jt76
Dec 06, 2020Guide
vajim wrote:Don't trust the app
many never use it
I have tried Adding Satellite through the web browser as well. No luck.
I now have the RBS50 ring LED flashing White now! I have no idea why the ring LED flashing Green before. The instructions in the web App say that the ring LED should be solid White. Not sure how to get it to that state.
- John_BaDec 07, 2020LuminaryI tried setting up a new system via pc wired and I wasn't able to get a link eather. Thy just came up with a msg re the app. I tried all the address I could find and in the end had to use the app. Some 50s may well have been setup to block wired setup, I am in the UK.
- jt76Dec 07, 2020Guide
So I went through multiple attempts of reseting the RBS50. Got the unit to flash white, and then using the web based interface added the Satellite once again. Worked! I am now able to see the satellite in the iphone App, as well as through the web browser.
Disconnected the power and moved the RBS50 to where it can provide coverage for the rest of the house. Connected it to power, and it continues to work.
Can't tell you what I did that was different the last time tp get it to work ! All I can say is keep on trying to reset the RBS50 unit and use the web interface to add the satellite.
- FURRYe38Dec 07, 2020Guru - Experienced User
What Firmware version is currently loaded on the RBR and RBS. They need to be the same version or will not work right.
