timh101
Mar 24, 2018Aspirant
Problem with Wifi on all Apple Devices on my Network
Hi all, I was wondering if anyone else had any experience with not being able to access a device that's currently connected to a different satellite. For example, if I was on my laptop in my bas...
- Mar 24, 2018
Is Daisy Chain and Fast Roaming enabled? Might disable these and test. Roaming will be a client device behavior as well.
The first wave to be released are only for the RBR50 and RBS50, which is used in the RBK50 and RBK53 (Costco) kits.
New beta FW avaialble. Get it while its hot of the press:
https://community.netgear.com/t5/Orbi/Orbi-MR-2-1-Update-3-23-18/m-p/1533584#M26234
