gilesy
Apr 21, 2021Tutor
Problem with wifi phone calls ONLY when a specific satellite is used
A strange problem has recently cropped up. My network comprises an RBR20 router, two RBS20 satellites and a RBS50Y outdoor satellite. It's all been working flawlessly until about a week ago when...
- Apr 21, 2021
Might check your phone. Has it been updated recently or anything changed?
Might swap the RBS around to see if the problem follows.
gilesy
Apr 21, 2021Tutor
Thanks both,
I'll preface my response by saying it all worked beautifully for more than a year and the internet connectivity is always fine; it's purely the use of my mobile phone.
The three satellites actually cover an office in the garden too, so there is probably 12-15m between all of them. The house itself is probably just over 2000sq ft plus the office. I do have neighbours who have wifi, but it's a very rural area and they're all at least 50ft from my house.
Apr 21, 2021Guru - Experienced User
- gilesyApr 22, 2021Tutor
By the way - the problem started when my son returned from university for Easter. It's all his fault.
- tak1313Apr 22, 2021Luminary
gilesy wrote:By the way - the problem started when my son returned from university for Easter. It's all his fault.
Yeah - the current gen is "all about me," including consuming all the bandwidth in the house.:smileyhappy:
You should see how much toilet paper my daughter uses - we have to buy ours from Costco!
Yes - I have that problem too here! He can try all he likes with the internet...I'm lucky to have fibre to the premises so even he can't ruin that, but he does like to tinker with the network.
