Nickmit
Oct 28, 2022Tutor
Problem With Wired Brother Printer
I have a Brother network printer connected by wire to my Orbi RB40. It correctly obtains an IP address from the router. When I look at the attached devices on the router it does not show the printer ...
- Oct 29, 2022
Hi Kevin and Plemans,
Ok, I've switched the Orbi to AP Mode and all seems OK so far. I can see the Printer in the list of attached devices. I'll keep an eye on it but hopefully that has fixed the problem I just find it odd that it seemed to manage to work as it was for 2 years and then suddenly failed.
Thank you both for your time & patience!
Oct 28, 2022Guru - Experienced User
What firmware is on the router and the satellite?
What modem/gateway is the router connected to?
Are the satellites using the wireless backhaul or wired backhaul?
- NickmitOct 28, 2022Tutor
Firmware is V2.7.3.22 on router and satellites. It is connected to a Fritzbox 7530. The configuration has been the same since December 2020. This problem only started happening on Saturday
Satellites are using wireless backhaul
- plemansOct 28, 2022Guru - Experienced User
Is the fritzbox in passthrough/modem only mode?
I've seen issues with double nats causing things like that
I'm not sure what mode the Fritzbox is in but wi-fi is not enabled and it is in a totally different ip range. It is http://192.168.178.1 and the Orbi is 10.0.0.1
This setup has worked fine for nearly 2 years and something must have changed in the last week to cause this but I have no idea what.
The printer used to be wi-fi connected and I initially thought that the printer wi-fi was causing the problem and that is why I changed it it hard wired but the problem still exists
