Nickmit's avatar
Nickmit
Tutor
Oct 28, 2022
Problem With Wired Brother Printer
I have a Brother network printer connected by wire to my Orbi RB40. It correctly obtains an IP address from the router. When I look at the attached devices on the router it does not show the printer ...
  • Nickmit's avatar
    Nickmit
    Oct 29, 2022
    Hi Kevin and Plemans,
    Ok, I've switched the Orbi to AP Mode and all seems OK so far. I can see the Printer in the list of attached devices. I'll keep an eye on it but hopefully that has fixed the problem I just find it odd that it seemed to manage to work as it was for 2 years and then suddenly failed.
    Thank you both for your time & patience!
