beckss1
Dec 14, 2018Tutor
Problem with wired connection RBR40.
Dear community.
I worked with my ORBI (RBR40) for 5 months and today I connect (wired) to router IX220 (LenovoEMC Storage). Two things happened, that I would like ask gurus:
1. After connection I...
michaelkenward
Dec 15, 2018Guru - Experienced User
LenovoEMC Storage is a network high density storage drive
Yes, I found that, but I could not understand how it related to this bit on the original message
"router IX220 (LenovoEMC Storage)".
What has "router IX220" got to do with "LenovoEMC Storage". Are they the same thing?
Is LenovoEMC Storage also a router? If not, how does this tie in with the idea that two routers are suddenly on the same network?
beckss1
Dec 17, 2018Tutor
Good morning.
Thank for all guys. First of all second question is not relevant (disconnect sattelite). It was resolved and find solution in my above post.
But about first question I try to clarify. I connect network storage (Lenovo) with wired to my router and thinker, that is router has IP 192.168.1.X and all attached home wifi devices into this WLAN, then also storage will be into above range IP.
What I need to define and please point me to relevant post for reading and understanding.
Thanks and regards.
Thanks and regards.
- michaelkenwardDec 17, 2018Guru - Experienced User
We still have not unravelled the answer to this comment from ekhalil
Looks that you have two routers providing DHCP functionality:What is the modem in front of all this?
It does not help that your latest message is puzzling. For example, what does this next bit mean?
beckss1 wrote:
I connect network storage (Lenovo) with wired to my router and thinkerThinker?
Then there is this bit:
router has IP 192.168.1.X and all attached home wifi devices into this WLAN, then also storage will be into above range IP.I'm baffled.
Sorry about that. Maybe someone else can interpret your message and what is going on.
- beckss1Dec 17, 2018TutorI try clarify situation
I have a ISP modem (connected before Orbi router). It IP is 10.0.0.X. and Orbi in give me IP 192.168.1.X. to all wifi devices. When I connect storage with network cabel to Orbi I see into mobile application, that it received IP 10.0.0.X+10.
I thanked, that all devices that connected to Orbi router will give me 192.168.1.X range.
Please reply if I can't explain right.
Thanks- FURRYe38Dec 17, 2018Guru - Experienced User
Thanks
