beckss1
Dec 14, 2018Tutor
Problem with wired connection RBR40.
Dear community.
I worked with my ORBI (RBR40) for 5 months and today I connect (wired) to router IX220 (LenovoEMC Storage). Two things happened, that I would like ask gurus:
1. After connection I...
Dec 17, 2018Guru - Experienced User
michaelkenward
FURRYe38 wrote:
Why we are trying to identify his ISP modem...
:smileywink:
If four or five of us say the same think, albeit in fewer words, perhaps we are on to something.
I can't wait to get the answer.
- ekhalilDec 17, 2018Master
Thanks michaelkenward and randomousity for confirming the theory :)
beckss1, as suggested in the first reply, please either bridge your ISP router or change Orbi to AP mode. We all believe that the root cause of your issue is the fact that you have 2 DHCP servers, leading to that different devices are getting IP addresses from 2 different DHCP pools.
- FURRYe38Dec 17, 2018Guru - Experienced User
Same here.... LOL
michaelkenward wrote:
:smileywink:
