Lorem
Mar 20, 2020Aspirant
Problematic connection to the RBR20
I'm having problems connecting the Ps4 console via LAN, together with another device, to the satellite of the mesh network that I configured a few days ago. Unfortunately, the device does not receive ...
- Mar 20, 2020
What is the distance between the router and satellite(s)? 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-routerWhat channels are you using? Auto? Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?Try enabling Beamforming and MIMO(MIMO may or maynot be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Set Short preamble instead of Long preamble modes. Save settings and reboot the router and satellite(s).Has a factory reset and setup from scratch been performed since last FW update?
Do devices connected to the RBR have a good connection there?
Lorem wrote:
I'm having problems connecting the Ps4 console via LAN, together with another device, to the satellite of the mesh network that I configured a few days ago. Unfortunately, the device does not receive a very strong signal, but despite this, the Wi-Fi connection works well. I therefore deduce that there may be a problem in the configuration of the satellite. Could you give me some advice or advice? Thank you!
Mar 20, 2020Guru - Experienced User
Lorem
Mar 21, 2020Aspirant
FURRYe38 wrote:What Firmware version is currently loaded?
The firmware loaded is the lastest: V2.3.5.26
ISP modem: Fastgate Huawei DN824SF
Home size: 120/150 sq
Distance between Orbi router and satellite: less than 10 meters
The problem with the transmission channel is that my area is full of Wi-Fi devices and all channels are congested, so I've decided to leave the selection of the channel on the automatic set. Another problem is that exactly in the nearest neightboor's room there is their modem that interfere with the satellite.
I tried to set the settings as you suggest, but there's not any significant change.
- FURRYe38Mar 21, 2020Guru - Experienced User
10meters maybe too close. 30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
If you area is congested with wifi signals and there is a neighbors wifi modem right next door, you may want move your system away from this area.
You can also turn down the radio output power on the RBR which may help some. Try 50%. Under Advanced Tab/Advanced Settings/Wireless Settings
