Markliley
Jan 16, 2019Aspirant
ProblemConnecting more than one Orbi outdoor to
I have a RBK50 inside and need to get WiFi in another building. With one outdoor Orbi it just gets there but with an intermittent strength. So I put another outdoor half way This one struggles to c...
ekhalil
Jan 16, 2019Master
This one struggles to connect.
Daisy Chain has to be enabled for this to work? Is it enabled for you?
Markliley
Thank you
Could you let me know how to set daisy chain on the Orbi outdoor
Regards
Mark
Regards
Mark
- ekhalilJan 16, 2019MasterDaisy Chain can be found under >>ADVANCED>>Advanced Settings >> Wireless Settings.
Please note that you need to have the nearest Outdoor Orbi synchronized with the router first so that it will start broadcasting its backhaul network that the second Outdoor Orbi will need then to synchronize to.
