Kerstens
Aug 17, 2020Aspirant
Problems after adding Netgear Orbi RBS50Y to network
Hello, One month ago we bought the RBK53 set from orbi. We put the router on the base level and on each other level another satellite. Everything was working very good. All devices connected to the ...
Aug 17, 2020Guru - Experienced User
Is Daisy Chain enabled on the RBR? Try disabling it.
Mstrbig
Aug 17, 2020Master
If you shut doew the RBS50Y, does the problem go away or do you still experience the issue? Try going to orbilogon.com and reboot.
