BDK2020
Feb 01, 2020Aspirant
Problems Connecting after SSID Change CBR40 - Please help
I have a CBR40 with two satellites, I changed the SSID to that of my old network so that all me devices would work and everything appeared to be working fine for a few months. Recently I have not bee...
Feb 03, 2020Guru - Experienced User
Has a power OFF of the CBR40 for 30 seconds been performed then back on. Connect a wired PC to the back of the CBR40 and use a web browser to access it's default IP address. 192.168.1.1 or .0.1?
IF this fails to gain access to the CBR40, a factory reset maybe needed. Press the reset button for 15 seconds then release. Walk thru the setup wizard with a wire PC and web browser. You'll need to reset the RBS as well. Wizard will ask you for a new custom SSID name and PW.
